Adds or deletes dedicated Application Hosting (IAH) or management ports to a virtual machine (VM).
| vm | Designates a virtual machine. |
| vm_name | Specifies the VM name to add or delete ports to. |
| add | Designates adding IAH ports to a VM. |
| delete | Designates deleting IAH ports from a VM. |
| ports | Designates adding or deleting ports. |
| portlist | Selects the IAH ports to add or delete. |
N/A.
Multiple VMs cannot use the same sideband port, but they can share the management port. To view ports for an existing VM, use the command show vm {vm_name | detail}.
This command does not take effect until the next time the guest VM is started.
The IAH feature requires the Solid State Storage Device SSD-120.
The following example adds port 1–5 to VM "vm1":
# configure vm vm1 add ports 1-5
This command was first available in ExtremeXOS 30.3.
This command is available on all platforms that support the Integrated Application Hosting (IAH) feature and have a Core or Premier license installed. For a list of platforms that support the IAH feature and for information about licenses, see the Switch Engine v33.1.1 Licensing Guide .
